Possible to change date format when exporting to a text file?
Currently, I'm using The Bat Voyager 5.0.32.1. I have a rule set up to export messages to a text file. When it does this, the date is exported as:
Wednesday, March 06, 2013 3:08:28 AM (UTC-06:00) Central Time (US & Canada)
This happens regardless of what date format I specify in Options -> Preferences -> Date/Time Format. I need to change this formatting, because messages go into an external app for further processing, and I can't sort with these long dates :(
Is there any way to make it export based on my preferences, instead of the long date listed above?
What template are you using to save to text?
You know what? I'm dumb :P I missed that big 'Template' button when I was looking at the Export dialog last night. I'll try tweaking that... thanks for your help :)
