Drag & Drop filtering
I switched to the bat from my old client. (my company forcing us from POP to Exchange servers)
With my old client, I could hold down ALT and drag a message from my Inbox to a folder, and it would auto-create a filter.
Does the Bat have this feature?
Nope, you can't do that with TB.
What you can do is:
Selcet a message
Press Ctrl-Shift-F
And next set the specific of the new filter.
You also can pick this function from the menu:
Specials -> Create Filter
ooo awesome. While not what I had in mind, it does the job I want. Perfect :)
Is there a hotkey for forcing a re-filter after I add a new one?
Sel ect the folder you want to re-filter and fr om the menu:
Folder -> Re-filter
Or select folder -> right mouse button -> re-filter
A lot of options/actions can be accessed by clicking on a folder or message and using the context menu that appears with the right mouse button.
There's no default shortcut, but you can cre ate them via the customizer (View -> Toolbars -> Customise)
good deal, thanks for the replies :)
Users browsing this topic (2 guests)
