Text and HTML version of mail Template
Is it possible to send both html and text version of the mail when using template. I have added %SETEDITOR="3" but how do I edit both part because they are slightly different. I cannot find anything or info. Thanks in advance.
They're supposed to contain the same text and you cannot alter that behavior with TB.
Maybe you are misunderstanding what I as asking. Your saying there is suppose to be no difference between a html copy and a text? That makes no sense, they are not suppose to be the same or there would be no point. Such as a link with html it would be wrap with a href, in text it would not. HTML tags would just be shown in text and be sloppy? Almost all email allows you to edit both the HTML copy and Text copy that is send and you can see in the header 2 separate messages too.
Cut from Header
Code
Content-Disposition: inline
Content-Length: 2686
Content-Type: text/plain; charset=utf-8
Content-Transfer-Encoding: 8bit
text copy of mail
Content-Length: 16057
Content-Type: text/html; charset=utf-8
html copy of mail
Edited: tbuser - 12.07.2011 19:21:18
The Bat! doesn't go for different messages. The text part is the same as the html part, apart from the tags, pics, etc of course, they're omitted in the text part.
