Hi When I use:
%QUOTES
I get a big nasty blue block in my replies.
How do I get rid of it? (I want to keep HTML formatting)
Igor
%QUOTES
Igor
Hi When I use:
%QUOTES I get a big nasty blue block in my replies. How do I get rid of it? (I want to keep HTML formatting) Igor |
Actually, I like the blue block. Now, if it was an ugly green, I'd want it out too!
Is there any way to control the quote marks? Get rid of the blue, turn it green etc?
Thanks Rick |
The only way to get rid of the blue bar left of the quotes is by not using the html editor.
I'm just a user of The Bat! I don't work for Ritlabs. |
Is it still not possible to change the color of these quotes? I love the way these quotes work - all I want is to change the color.
I have asked developers about possibility to define this colour, we should wait
Is there anyway of making the blue block thinner? I can manually remove the > from the bar and then manually reduce the width of the block. Is there no way to change the template so it automatically looks like this?
It looks alright if it's very narrow - but otherwise it looks like a nasty piece of formatting, and not particularly suited to business use.
Edited: |
Daniel, in next final build, > will be removed in blue column, co it will be thinner.
Has this finally been solved? IS there a way not to have that blue column in replies?
Yes, it should be an option to remove it. (I have gotten several comments from correspondents to the effect of "What's with that blue bar???")
