Acces violation
Acces violation
Get VERY OFTEN the error message:
Access violation at address XXXXXXXX. Read of address XXXXXXXX
(addresses vary)
When?
Deleting a 'open' message
After sending an e-mail
Pasting text in a message
etc etc.
It applies to all my accounts.
Tried maintenance centre many times.
Nothing helps.
Please advice how to solve this nasty problem
Many thanks,
Cees
What version are you using?
OTFE, IMAP, plug-ins?
No OTFE, nor IMAP. Just pop
Version 3.85.03
no plug-ins, already deleted bayesit etc etc
just 2 virtual folders for junk mail in several accounts and virtual folder for trash in those accounts.
For the rest a 'normal' configuration
:D
In that case you shouldn't get any AVs, that's a pretty stable release.
Did you try to install it again or to repair the installation?
Just delete thebat.exe and via:
Start -> Configuration screen -> Software -> The Bat! -> Repair
Just deleted thebat.exe and did the repair.
Didn't help. Problem still there. :(
Is this summary of ex_log.txt helpful to you?
Regards,
v3.85.03 USER/Dhr. Prins 21-11-2006 14:45:32 RasMon:4 EAccessViolation Access violation at address 7C901010 in module 'ntdll.dll'. Read of address 0000001C
v3.85.03 USER/Dhr. Prins 21-11-2006 14:53:16 RasMon:4 EAccessViolation Access violation at address 7C901010 in module 'ntdll.dll'. Read of address 0000001C
v3.85.03 USER/Dhr. Prins 22-11-2006 07:45:22 GUIDEF:Cannot bind layout item [ViewFrame].[mMessageDataDownloadMode]
v3.85.03 USER/Dhr. Prins 22-11-2006 07:45:22 GUIDEF:Cannot bind layout item [ViewFrame].[mReloadImages]
v3.85.03 USER/Dhr. Prins 22-11-2006 07:45:22 GUIDEF:Cannot bind layout item [ViewFrame].[mShowURLManager]
v3.85.03 USER/Dhr. Prins 22-11-2006 07:45:24 ABCGrid:6 EAddrBookDuplicate Duplicate handle
v3.85.03 USER/Dhr. Prins 22-11-2006 08:42:56 GifImage:5 EReadError Stream read error
v3.85.03 USER/Dhr. Prins 22-11-2006 11:16:26 GUIDEF:Cannot bind layout item [ViewFrame].[mMessageDataDownloadMode]
v3.85.03 USER/Dhr. Prins 22-11-2006 11:16:26 GUIDEF:Cannot bind layout item [ViewFrame].[mReloadImages]
v3.85.03 USER/Dhr. Prins 22-11-2006 11:16:26 GUIDEF:Cannot bind layout item [ViewFrame].[mShowURLManager]
v3.85.03 USER/Dhr. Prins 22-11-2006 11:16:28 ABCGrid:6 EAddrBookDuplicate Duplicate handle
v3.85.03 USER/Dhr. Prins 22-11-2006 12:04:26 GUIDEF:Cannot bind layout item [ViewFrame].[mMessageDataDownloadMode]
v3.85.03 USER/Dhr. Prins 22-11-2006 12:04:26 GUIDEF:Cannot bind layout item [ViewFrame].[mReloadImages]
v3.85.03 USER/Dhr. Prins 22-11-2006 12:04:26 GUIDEF:Cannot bind layout item [ViewFrame].[mShowURLManager]
v3.85.03 USER/Dhr. Prins 22-11-2006 12:04:28 ABCGrid:6 EAddrBookDuplicate Duplicate handle
v3.85.03 USER/Dhr. Prins 22-11-2006 12:10:13 GUIDEF:Cannot bind layout item [ViewFrame].[mMessageDataDownloadMode]
v3.85.03 USER/Dhr. Prins 22-11-2006 12:10:13 GUIDEF:Cannot bind layout item [ViewFrame].[mReloadImages]
v3.85.03 USER/Dhr. Prins 22-11-2006 12:10:13 GUIDEF:Cannot bind layout item [ViewFrame].[mShowURLManager]
v3.85.03 USER/Dhr. Prins 22-11-2006 12:10:15 ABCGrid:6 EAddrBookDuplicate Duplicate handle
v3.85.03 USER/Dhr. Prins 22-11-2006 12:11:04 GUIDEF:Cannot bind layout item [ViewFrame].[mMessageDataDownloadMode]
v3.85.03 USER/Dhr. Prins 22-11-2006 12:11:04 GUIDEF:Cannot bind layout item [ViewFrame].[mReloadImages]
v3.85.03 USER/Dhr. Prins 22-11-2006 12:11:04 GUIDEF:Cannot bind layout item [ViewFrame].[mShowURLManager]
v3.85.03 USER/Dhr. Prins 22-11-2006 12:11:06 ABCGrid:6 EAddrBookDuplicate Duplicate handle
v3.85.03 USER/Dhr. Prins 22-11-2006 12:20:39 GUIDEF:Cannot bind layout item [ViewFrame].[mMessageDataDownloadMode]
v3.85.03 USER/Dhr. Prins 22-11-2006 12:20:39 GUIDEF:Cannot bind layout item [ViewFrame].[mReloadImages]
v3.85.03 USER/Dhr. Prins 22-11-2006 12:20:39 GUIDEF:Cannot bind layout item [ViewFrame].[mShowURLManager]
v3.85.03 USER/Dhr. Prins 22-11-2006 12:20:41 ABCGrid:6 EAddrBookDuplicate Duplicate handle
Not to me, but I'll pass it on.
I have the same problem:
Access violation at address 7xxxxxx in module 'ntdll.dll'. Read of address xxxxxx
It appears when I try to search in my LDAP (configured by myself) directory. Then I could not close the dialog of searching and I must kill whole THE BAT!
I tried version 3.60Pro and 3.71.01Pro with the same result.
Stanky, please check 3.85 and if it will happen too, please include whole AV numbers.
Thanks. I tried ver. 3.85 without any error messages. 8)
