X-custom header field in column view of mails
X-custom header field in column view of mails, X-custom header field in column view of mails
I have a custom header field (say x-custom) and would like to have one of my columns in my emails view show this. The custom field is created and I can use the bats other features on this, but cannot see how to add it as a column.
Could someone please advise.
Thanks
It looks like this can't be done other than using filtered views which isnt exactly what I would like.
What is the best way to recommend that this be added as a feature?
Thanks
Add it to the wish list and advertise for support:
You can insert wishes in the wish list, by logging in to:
https://www.ritlabs.com/bt/main_page.php
Choose 'The Bat! wishes' and add a new item.
First check whether someone has made the same wish, then you can
support that wish.
Wishes that are supported by more users are more likely to be granted
than wishes by one. And the system isn't smart enough to understand
that wishes might be the same.
And add just one wish per entry. Makes everything easier, both for
other users who want to add support and for the developers.
