Default Reply template
Can anyone tell me what is the Default Reply template?
Best regards,
Kodiak
you can see it by clicking
Account Properties -> Templates -> Reply
In case you modified it, and want to revert back to the default - create a new account and copy template from there.
Hi there.
It gives me this template:
Dobrэ den,
%ODate, %OTimeLong, napsal jste:
%Quotes
%Cursor
S pozdravem,
%FromFName
%FromAddr
I believe I've installed from a Russian Installer. Wen I use the V3.x it was a different template
Best regards,
Kodiak
Miguel,
The language of the templates that are created when you create a new account is the same as the language of the interface, so when you change the interface to English you get English template and when you set the interface to Portugese you'll get Portugese templates on creating a new account.
Hi.
Many thanks.
That solved my problem.
Best regards,
Kodiak
