HTLM template and reply
Hello,
If I reply to a message which is only in plain text, HTML model is applied.
If I reply to a HTML message , HTML model is not applied.
Why?
In advance, thanks for your reply.
it depends on what You have set in Preferences dialog, section Viewer/Editor.
You can select default editor and there is an additional option "Reply to HTML in pain text".
Hello,
Options > Preferences > Viewer Editor:
- Default editor for text: HTML with alternative plain text part
- Reply to HTML in plain text is selected.
If I reply from a HTML message with F4:
1. Document background in template is not respected.
2. Format Text (colour,...) set in the template is respected until the quotation, after, format text is not respected.
If I do not selected text before pressing F4, the entire message is placed in quotation
Edited: Sacles - 29.12.2008 11:03:53
hi
Marek Mikus: changing this setting doesn't change the situation.
Sacles: exactly!
I think there is a problem with processing of reply template to html messages..
thanks for reply,
m
Edited: Mike W - 29.12.2008 11:54:40
