Removing some subject contents to allow threading
I'm trying to modify the incoming subject of a message to remove some index information so that the messages can then be threaded by subject.
The plan is to create a filter which creates a new formatted message with the modified subject. What I don't understand is how to remove the information from the subject.
eg.
Warehouse Installation Issue [16349]
should be converted to:
and any replies
RE: Warehouse Installation Issue [16350]
to
Any pointers on how to achieve this gratefully received.
Cheers
Richard
Without third party tools TB doesn't allow for changing received messages, but this might be a pointer: http://cgi.silverstones.com/library.php#mssg__header_editor
Hmm...
I thought I would be able to create a new message with the contents of the original but with the subject modified. The original could just be deleted and the new message used in it's place.
Thanks anyway.
Richard
