Delayed mails not working anymore
Hello, using v 4.2.10.1, i started to use delaying mails yesterday... and today, they are not working anymore !? I didn't change anything in te configuration, the only "change" was :
- this morning i wrote a message (which was delayed for 5 minutes with the same macro that worked yesterday : "%POSTPONE="5m"), and then closed immediately TheBat!
- the message was not sent (this is correct considering TheBat! was closed :-) )
BUT
- after reopening TheBat!, the message wasn't send, even with anoter 5 minutes delay,
- AND every new message is NOT sent anymore.
Any idea ?
Thanks in advance !
Christophe
www.cabinet-antoine.fr
I had exactly the same problem. Update: It worked today, but then not again in the evening...
Edited: Supa Dev Two - 02.10.2009 02:09:50
Same problem here... can someone please provide a solution to this!
did You tried 4.2.16?
Ok,
re-tried with 4.2.18, and it works !
Thanks
Christophe
Correction,
The problem is still here :
- if i send a mail on 8:30, with %POSTPONE="5m", then close TB and re-open it on, say, 8:32, the mail will be sent,
- if i do the same, and re-open TB on 9:00, the mail will stay in outbox.
Seems that you should add a checkup of the outbox, for delayed mails, so to re-schedule them...
Hope this helps !
Christophe
so there's really no solid solution for this?
I am having the same problem. Not sure if I'm doing something wrong. I have a delay on my auto Responses. Sometimes they send out on time, sometimes they just pile up in the out box.
Any Solution for this??
