There is any antispam plugin which works with the bat!? I had AntiSPamSniper but it stops working.
Thanks.
Thanks.
Thanks. |
What version of The Bat! and what version of AntispamSniper you use? AntispamSniper v. 3.3.5.3 works fine with all versions of The Bat!. Have you updated the plugin?
No, it not.
