How can I reset interface to the default (view and bars) and - if necessary - go back to the previous one without having to set everything up from scratch? Thanks.
I think you can delete (well, rename) TBUSER.DEF in your Mail folder, and The Bat will recreate a new copy of this file with default settings when you next launch The Bat. Please give that a try, and if it should not work, just exit the program and restore the file to its previous state.
For descriptions of the various files used by The Bat, see: (the listings are rather old, but I believe most files mentioned haven't changed much).
I've already tried this before asking here, but thanks. This works only for toolbars.
