how to match the following address
I want to match the address like [email protected]
but don't want to match the address like [email protected]
how?
Presuming you want to do that in a filter....
Create an address book group called 'matched addresses'
Create a filter that checks whether the address book groups matched addresses is containing the sender address.
thanks
there is another problem,
how can i match any one of recipients by using address book groups.
eg:
address groups: [email protected]
match this: recipients: [email protected], [email protected], [email protected]
don't match this: recipients: [email protected], [email protected], [email protected].
Don't make it more difficult than it has to be.
Only add the the addresses that you want to match to the address book group you're testing it against. It doesn't matter whether you check that AB group against 'any recipient', 'all recipients', 'sender' or whatever.
