I'm getting the upgrade splash page when I open The Bat! If I upgrade to 11 (from 10.x I purchased when it was released) will that mean I'm no longer a registered user and have to pay to continue usage?
Depends on when exactly you purchased v10: if it was after June 1 2023 the upgrade to v11 is free, otherwise you need to buy the new license. See here:
Also, some people reported problems with the free upgrade and had to contact support to get it fixed.
Edited: |
It was earlier than that when I purchased it. I'll stick with V10. Nothing is needing me to go to 11.
