Selecting Multiple or ALL subfolders.
There are many times I need to select all or many folders. Is there a way to select more than one folder in this example?
My folders: For this example, I have a folder called Vendors, and under Vendors, I have 150 subfolders.
Create a virtual folder>Click "Select Folders", Put a check in the box next to Vendors, Expand the Vendors Folder, see that there are no subfolders selected, Try and select all of the Subfolders without clicking on each one of them.
Is there a way to do this?
Jason
You can do it clicking on Vendors with Ctrl key?
Excellent! Thank you!
