Hello,
I'm using The Bat! Pro 9.5.1 x64 under Windows 7 Pro (fully patched).
I own numerous domains, two of which I'll call dom1.com and dom2.com.
When I write a message as , I would like it to be sent by the dom1.com account so that when the message is received, it is not signaled as spam. (I have checked this, and it works.) Of course, if I'm paying attention, before I hit the Send button, I can change the Active Account in the bottom of the Edit Mail Message window, but I often forget this critical step.
My idea, then, is to create a filter that uses RegEx to determine the sender's domain and change the active account to the one created for that domain. So, the message written by would be sent by the Active Account for dom1.com.
Can an outgoing filter do this? If not, is there any way I can display a message before any message is sent to check the Active Account?
regards, AndyA
regards, AndyA
