Filter - adressgroup to folder - help !!!, Moving msg from adressgroup to select folder
Can anyone help me ???
I wont filter msg from adressgroup to a folder
Filter
General
adressgroup/[friends]/contain/sender
Action
move to the folder
Option
this filter is active
immediately
it wont work
thanx ;)
This should work. What version do you use?
In case you don't use 3.01 try to download that from http://www.ritlabs.com/en/products/thebat/download.php
When you're already using 3.01 you could try to move it to the top of your filter list (you're using it as an incoming filter?) when it works then, another filter is interfering with it in your current setup
