Manually Execute Single Filter
I can (and regularly do) use Quick Templates to manipulate messages and had hoped that there would be a similarly simple way to use "Quick Filters", by which I mean manual filters that can be selectively applied to whole folders or selected messages. I have not been able to find a way of executing a single filter. Have I missed something obvious?
Regards, John Mitchell
In the 'options' tab of the fi;ter you can assign a hotkey to a filter, you can even configure it such that it only will be executed with that hotkey.
I hope this suffices for your needs.
I'll give it a go. Thanks. What surprises me is that there is no option to just double click a filter to execute it.
Regards, John M
