Filter is not working in the Bat V3, something is wrong with the strings
Hi.
There is a problem with the V3 of the bat.
You know, there are control characters at string definition.
The fact is, that the Pipe character ( | ) is not working! :(
Actually i can't define more strings in one line in an OR relation now.
i tried [aa] | [bb] in example, and the filter did not work when the mail contained aa, or bb!
In this new filtering system, there is a thing, named "contains any of", i tried the pipe character
with this too, and not worked at all!
Please fix this bug, or tell me how can i define more alternate strings in one line in that new
filtering system!
Just hit F1 while editing a filter and the new structure is clearly explained.
The | character has no place in the new filter system. Instead, enter multiple strings on separate lines in the match box.
iviarck
Actually i tried this, but the 2.x help system is what brought to me.
Aaahhh... ...Just an ENTER :D
...How could i such a stupid :) (not getting to that)
Anyway, thanx for your help!!
Install the latest version of TB. That should include a current help file.
I'm using the latest version of TB V3.
Maybe the previous installation of TB (V2) is confused the V3-install? (I upgraded from V2)
Anyway, i solved that problem:
I deleted the 2.x help, then i ran the install MSI, and chose REPAIR. Then it put me the 3.x help. :)
