Using macros as parameters for external action, Using macros as parameters for external action
I don't know how to use a macro to pass a message property as a parameter to a external action:
If I try program.exe %From, it doesn't seem to pass the sender as a parameter. The string "%From" is received instead.
Does anyone know how to do this?
Thank you.
Is a known bug, it won't work, I don't know whgether it has been fixed in the latest beta.
However, there's a workaround.
Use the action 'Export message to plain text file', save to the file 'C:\action.bat' (or whatever path/name you prefer as long as the extension is .bat or .cmd (what OS are you using?))
Use as template something like:  program.exe  %From
As the next action ru external program c:\action.bat
This will do what you want. Remember you need to execute the actions in the proper order (top down), first the exporting afterwards the external action.
