The Bat 5.0.12 : Quick Templates various problems
Hi there,
A quick template with a table will not show table & content at all.
An other problem : a quick template with a link, will use a different font (times new roman) and size (14) for the link instead of the chosen font for the template.
I am using the last version 5.0.12. And it occurs with all new quick templates.
Regards,
I just forgot to give a detail : it's when you insert a Quick Template with CTRL+SPACE shortcut.
i have some problem with the Quick template. Some editing with different font doesn't work in v5.0.12. Main problem is found when i try to create a html link. Always i can't find my desired font settings.
Users browsing this topic (2 guests)
