Hi all - just trying out Bat, I like it but already see a quirk. When I set Format to 'HTML' in a new template I make, it apparently keeps it, but when I then go to compose new email with that template, the format defaults to 'Plain' and I have to still choose HTML manually. This is tedious and is not something you have to do in Thunderbird, for example. How do you get the format to stick when composing from a template?
Also I'm trying to paste graphics here to show, but they are showing blank frames. Any trick to that? I'm going to leave them pasted in here in the chance you can see them. Thanks!
[IMG WIDTH=762 HEIGHT=248]file:///C:/Users/laten/AppData/Local/Temp/qfivgih1.w24.png[/IMG]
[IMG WIDTH=810 HEIGHT=388]file:///C:/Users/laten/AppData/Local/Temp/y0pal44n.hrz.png[/IMG]
