5.0.8 Bad Behavior
Since installation, have noticed:
1. Extremely slow loading. TheBat! loads as part of boot processing, Vista. Often requires ~8 minutes to loat to getting messages. This is entirely NEW behavior.
2. The Connection Center log remains empty.
3. When sending MAPI-launched e-mail, receive the following error:
Exception ECriticalSectionsLeak in module TBMapi.dll at 000116F5
Mail is dispatched OK.
Added 5/3: All fixed in 5.0.12
Edited: Curt Akin - 03 May 2011 15:19:57
I've noticed a slow loading of messages, myself - but man . . . . . . . 8 minutes is a darn looooong time.
cheers,
(^ _^)
Battie
Windows Se7en Ultimate (SP-1)  |  The Bat! Pro 5.0.10 (Beta)
If you are getting real slow loading try cleaning out the cache and imgfiles folders
I assume you are also running the maintenance center on a regular basis too
I have a batch file that I use with these lines:
del /Q "C:\Documents and Settings\Rick\Application Data\The Bat!\cache\*.*
del /Q "C:\Documents and Settings\Rick\Application Data\The Bat!\imgfiles\*.*
You have to adjust them for your path of course
I hope that helps
Rick:
Yes, helped some. Still doesn't load near as quickly as 4.
Thank you.
I've customized my CCleaner to clear the 'cache' and 'imgfiles.'
cheers,
(^ _^)
Battie
Windows Se7en Ultimate (SP-1)  |  The Bat! Pro 5.0.12 (Beta)
