convert mails The Bat! in outlook 2007
Hello,
Using The Bat! Outlook 2007 and in parallel, it is impossible to open a mail register. msg with the bat! from Outlook. I read on various forums that the. msg The Bat! can not be read with Microsoft software. I tried various conversion software but to no avail.
On the other hand I can not save the mail. Eml since the function save as ... does not work with some mails (weird problem).
could you tell me about the method so that my emails can be used in both software without any problems.
Thanks  :D
AFAIK you should be able to save every message as .eml
If 'save as' doesn't work, use the export function (Tools -> export messages to...)
I don't understand why you want to export/import messages from both clients, why don't you configure both clients to leave messages on server for a day or two, that way you can download in the regular way.
Another way would be to configure your mail account as IMAP.
