the bat not checking emails automaticly and it is not sending, not checking emails automaticly
so my bat is no longer checking emails every 5 minutes I have to hit the send and receive button, and when I get the msgs off the hotmail server it just puts them in the outbox and I have to highlight them all and hit unpark and then send.
I need to make it so it checks the mail and sends the replies every 5 minutes I have it set to that in settings but it is not working.
Thanks alot
Just to be sure. You know that that's an account based setting? So you need to configure that in every account separately.
well I use the same hotmail account on 5 different bats, I have the bat installed on 5 computers each bat logs into the 1 same hotmail account username@hotmail.com I setup, then I have a different smtp server that I pay for to sent my outgoing emails with, and I have 5 different replies with 5 different cpa links, so they get spammed 5 different times.
Where would I fix this setting in the hotmail account? so I do not have to hit send and receive to get my emails and then it puts it in the bat outgoing folder but does not send them I have to hit select all the unpark them then send.
trying to automate the emailing
thanks
Edited: paul420 paul - 07 August 2011 23:16:53
It's not in your hotmail account, but in the ccount settings of TB.
'Account -> Properties -> Options -> Mailbox checking' for the frquency
and
'Account -> Properties -> Transport -> Combined delivery' for sending with every check
ok I got it fixed so it sends the msgs right away but it still does not check the email box automaticly, I have it set to periodical checking each 5 minutes and nothing goes through, I then change it to seconds and it does nothing,
I have Mailbox checking the tabs underneath are
check mailbox at start-up is checked
periodical checking each 5 minutes is checked
mark message as read when it is bereing read for unchecked
mark message as read only when it is open in a seperate window unchecked
verbose log uncheck
maximum log file siz is 20 k bytes
ignore check all accounts request unchecked
allow send fetch without enterint the access password (if any) unchecked
empty trash folder on exit unchecked
compact all folders on exit unchecked
Message Editor Settings
Confirm Immediate Sending unchecked
Sign When Completed Unchecked
Encrypt When Completed Unchecked
Confirm Unencrypted sending Unchecked
Enable OPenPGP unchcked
Unebale S/MME unchecked
do i need to check uncheck any of these?
ok so its the next day, now I check it again
now on the vmware machines its working fine and sending everything out
on my main windows 7 machine it is not checking it.
I will try to uninstall and reinstall it and report back later
