transferring TB! data to another pc, transfer The Bat to a different pc
I'm having a bit of problems transferring The Bat! to a new pc.
The problem is I'm running out of disc space on the old pc. I got 1% left. Machine is slow as hell... probably for that reason the backup fails. It starts, but gets stuck somewhere and I have to manually close The Bat! from the Task Manager.
I made a full copy of all the files, and transferred that to the new pc.
The settings are default: C:\Documents and Settings\user\Application Data\The Bat!\user.
I copied everything in The Bat! folder to the new pc, in a directory I named Mail. So instead of C:\Documents.... etc. the new directory will be Mail\....
Can I install The Bat! on the new PC, and point it to the respective user folders?
A not related question, but purely out of interest: what is the difference between Inbox - Know and Inbox?
Edited: Jos Flachs - 13 September 2011 13:39:22
Hi Jos,
The easiest way IMHO is to backup TB, install on new machine and restore the backup file.
Can you backup directly to say a USB key ?
Edited: Lord Melch - 23 September 2011 21:43:30
Cheers
MS
