Running an archive of messages and attachments fully off a DVD or memory stick install of TB! ?
Having had issues with a backup and restore I have now reviewed how I useTB! and have a couple of technical queries. I currently have a vast database of e-mails and attachments going back several years in my The Bat! directories. I am wondering if I can cause a standalone copy of TB! to run an archive of read only message and attachments direct from a DVD, memory stick, or an external drive, so if I need to refer to an aged e-mail with attachment I can do so easily, without having a huge database of e-mail and attachments stored on my main PC or laptop? If this is possible, how would I do this please?
Finally, how would I delete messages and attachments on my current intstallation going back to before a given date, given the attachments are stored in a seperate directory under the main The Bat! directory, not with the messages themselves? I am sure a deletion based on a dates "up to", or "after" is possible, but I haven't figured it out yet. Thanks.
theBat has an undocumented /Reg: switch - using it, you can start the program with different settings - in your case a different mail folder
Normally theBat uses registry settings fr om
HKEY_CURRENT_USER\Software\RIT\The Bat!
If you start it like
thebat.exe /Reg:archive
(it's easy to create a shortcut for this)
then it will use the settings fr om
HKEY_CURRENT_USER\Software\RIT\The Bat!archive
HKEY_CURRENT_USER\Software\RIT\The Bat!archive   is a key you have to create, initially it should be an exact copy of HKEY_CURRENT_USER\Software\RIT\The Bat!
Then simply change the "Working Directory" value under the newly created key to point to the folder where your archive is.
Needless to say, if you use an external drive it should be mounted prior to starting theBat with /Reg: switch , and should be always mounted as the same drive letter.
But with hard disk space being so cheap these days, I doubt the above makes sense - you can simply keep your archive on HDD.
About deletion of old messages, you can make a filter with a condition like
Date of reception -  is before - [some date]
and action like
Move the message to folder [some folder]
In filter options set it should be used for manual re-filtering only, then re-filter desired folders (right click -> Re-filter) - old messages will go to the specified folder. Then you may delete that folder from theBat - right click on it -> Delete -> select Wipe - this will delete theBat folder and the associated msg base file.
PLEASE NOTE: I use an old version - 3.85. Some of the above may not be applicable to newer versions, though I doubt. To be on the safe side, before doing anything make a full backup of your mail folder with WinRAR or another archiver.
I have never stored attachments separately. To delete old attachments, you may simply sort the folder wh ere they are stored by date (in Windows Explorer, when theBat is closed) and then delete what has to be deleted.  I have no idea how filters process separately stored attachments.
Edited: bigg one - 29 December 2011 02:32:13
Thanks again bigg one, that's very interesting and sounds like it will do the job. I'll have a play with this over the holiday weekend, many thanks for such a clear and detailed description, but I'll be sure to do a proper backup first! All the best, cheers!
helinlin20171028michael kors outlet clearance
yeezy boost 350
ugg sale
coach outlet online
coach purses
canada goose jackets
red bottom heels
uggs outlet
coach outlet online
kate spade handbags
moncler sale
cheap ugg boots
cheap jordan shoes
moncler coats
harden shoes
polo ralph lauren outlet online
yeezy boost
michael kors
adidas store
uggs outlet
canada goose
ugg outlet store
canada goose clothing
michael kors outlet canada
nike air max 2018
tory burch shoes
canada goose sale
birkenstock shoes
adidas sneakers
canada goose coats
uggs outlet
coach outlet store online clearance
adidas yeezy boost
salvatore ferragamo shoes
mlb jerseys whgolesale
ugg outlet
the north face outlet
michael kors uk
coach factory outlet online
moncler
pandora jewelry
kate spade handbags
longchamp outlet
oakley sunglasses outlet
canada goose sale
pandora charms outlet
ferragamo outlet
uggs clearance
uggs
uggs outlet
canada goose outlet online
the north face jackets
coach outlet online
nike outlet store
michael kors
canada goose jacket
ray ban sunglasses discount
uggs on sale
polo ralph lauren
ray ban sunglasses sale
cheap air jordans
ugg boots clearance
uggs outlet
mbt
north face outlet
michael kors outlet online
adidas outlet store
louis vuitton outlet store
ugg boots outlet
cheap ugg boots
louis vuitton handbags
ugg outlet online
tory burch outlet online
adidas yeezy shoes
adidas superstars
michael kors handbags outlet
uggs outlet
michael kors outlet store
coach outlet online
cheap jordan shoes
ralph lauren sale
canada goose coats
ralph lauren sale
coach outlet online
ugg outlet online
birkin handbags
polo ralph lauren
coach outlet store
coach outlet online
uggs clearance
ugg boots
cheap ugg boots
burberry outlet
pandora charms sale clearance
retro 11
pandora charms
coach outlet online
ugg outlet
coach outlet online
michael kors bags
yeezy shoes
canada goose outlet
moncler coats
ugg boots
coach factorty outlet online
cheap air jordans
air max
canada goose outlet
moncler coats
longchamp bags
north face jackets
coach outlet online
discount oakley sunglasses
moncler pas cher
ugg outlet store
ugg boots
adidas nmd r1
adidas ultra boost
ugg boots
adidas nmd r1
adidas yeezy boost
ugg boots
cheap jordans
red bottom
caterpillar boots
pandora charms
bottes ugg
ugg boots
hermes outlet
kate spade outlet
christian louboutin sale
pandora charms sale
adidas nmd runner
uggs outlet
ralph lauren
canada goose
uggs outlet
longchamp sale
ugg outlet
fred perry shirts
cheap nfl jerseys wholesale
nike outlet store online
ray bans
yeezy boost 350
yeezy shoes
burberry outlet online
adidas outlet store
canada goose sale
cheap jordan shoes
canada goose sale
canada goose sale
coach outlet online
air jordan shoes
mbt
ugg outlet
toms outlet
canada goose coats
uggs outlet
coach outlet online
coach outlet online
toms shoes
moncler outlet online
timberland outlet
ray ban glasses
adidas outlet online
adidas nmd runner
fitflops sale clearance
cheap oakley sunglasses
canada goose outlet
ugg boots
kate spade outlet online
ugg sale
burberry handbags
uggs
uggs outlet
ugg australia
ugg boots women
coach outlet store
moncler uk
nike huarache shoes
gucci outlet online
ugg outlet store
toms
pandora charms
air jordans
moncler sale
north face outlet
louis vuitton outlet online
moncler coats
ray ban sunglasses outlet
cheap jordans free shipping
pandora outlet
uggs clearance
nike outlet online
coach outlet online
ray ban sunglasses cheap
ugg boots
ugg boots
moncler jackets
toms
coach outlet online
uggs outlet
supreme shirts
kate spade outlet
pandora jewelry outlet
canada goose coats
columbia sportswear outlet
supreme uk
uggs outlet
ferragamo shoes
nike cortez classic
ugg boots clearance
hermens
ugg slippers
burberry handbags
ugg boots
coach outlet online
cheap nfl jerseys
uggs outlet
ugg boots outlet
coach outlet canada
canada goose uk
cheap nike shoes
adidas superstar shoes
canada goose parka
cheap uggs
louis vuitton factory outlet
nike shoes
coach handbags outlet
ugg sale
uggs outlet
christian louboutin shoes
salvatore ferragamo outlet
ugg outlet online
ugg boots sale
coach outlet canada
coach outlet online
uggs outlet online
ralph lauren uk
michael kors bags
gucci outlet
ugg boots sale
uggs outlet
ugg shoes
mulberry uk
cheap ugg sale
timberland outlet store
ugg boots on sale
polo outlet online
nike outlet
uggs
adidas yeezy boost 350
ralph lauren sale
adidas shoes
canada goose outlet
nike sneakers
ugg boots
cheap jordan shoes
ralph lauren sale clearance uk
hermes bag
nfl jerseys
jerseys cheap
michael kors
pandora uk
nike shoes
north face jackets
nike outlet store
coach outlet online
coach outlet online
valentino
jordan shoes
nmd adidas
fitflop sandals
hermes bags
ugg sale
hermes bags
ugg boots
canada goose sale
birkenstock outlet
uggs clearance
mulberry handbags
ugg boots outlet
air jordans
yeezy boost 350
coach outlet online
nike sneakers
ugg boots
canada goose outlet
cheap uggs
cheap ugg boots
canada goose coats
uggs sale
birkenstock uk
fred perry polo shirts
mlb jerseys
ugg canada
birkenstock
cheap ugg boots
pandora charms
ugg outlet
pandora jewelry
cheap ray ban sunglasses
ray bans
louboutin outlet
uggs outlet
longchamp outlet store
ugg outlet
canada goose coats
coach outlet online
mulberry
ugg canada
ugg australia outlet
coach outlet
ugg on sale
michael kors
canada goose jacket
coach outlet online
louboutin outlet
red bottoms
ugg boots
uggs outlet
canada goose outlet
ralph lauren
moncler jackets
ralph lauren outlet
ray bans
louboutin shoes
ugg outlet
discount ray ban sunglasses
coach outlet online
moncler
cheap uggs
moncler jackets
harden vol 1
pandora
cheap jordan shoes
valentino outlet
coach outlet store
coach outlet online
uggs outlet
nike outlet online
toms
cheap jordans for sale
ralph lauren outlet
coach outlet store
mulberry outlet uk
canada goose uk
moncler sale
burberry handbags
north face sale
ray ban glasses
cheap ray bans
kate spade handbags
ugg boots outlet
mlb jerseys
ugg outlet
air jordan retro
yeezy shoes
air max shoes
canada goose outlet
hermes handbags
supreme clothing
toms
jordans
cheap ugg boots
ugg boots outlet
longchamp bags
ralph lauren outlet
moncler jacket
canada goose sale
pandora jewelry store
uggs outlet
cheap air jordans
longchamps
ugg
adidas nmd r1
air max
helinlin20171028
