When I try to save a message externally I get an error message telling me that a specific folder path does not exist - which is quite correct, but I cannot find where to change the default folder. Can anyone help? Thanks in advance.
There is no default folder. The save as function comes with the path you used the previous time. So simply change the path to an existing location and the next time TB will prompt with that.
