Command line to open a new message with an attachement
Is there a way of opening a new message window from the command prompt and include an attachment like this:
thebat /new /attachment:report.pdf /email:123@abc.com
I'm using BAT 4.0.38 Pro
Thanks,
Andy
Thank you,
Andy
Team work makes the dream work.
The BAT! 6.7.36 x64
See the help file:
Help -> Help topics -> Advanced use -> command line parameters -> /mail
Thanks Roelof,
Roelof Otten wrote:
See the help file:
I'm using Access2007's VBA with a string like:
C:\Program Files\The Bat!\thebat.exe /MAILU='Andrew M. Bott';SUBJECT='PO 104001-4900034574-LCPI-2';ATTACH='D:\My Documents\Rubber\Suppliers\LCPI\PO 104001-4900034574-LCPI-2.pdf'
Nothing happens: no errors, nothing.
I've even tried: C:\Program Files\The Bat!\thebat.exe /MAIL
But, nothing happens here either.
Any ideas?
Thanks,
Andy
Thank you,
Andy
The BAT! 6.7.36 x64
PS I'm using the SHELL("") function and I've used this function with many other apps many times before.
Thank you,
Andy
The BAT! 6.7.36 x64
Try "C:\Program Files\The Bat!\thebat.exe" /MAILU='Andrew M. Bott';SUBJECT='PO 104001-4900034574-LCPI-2';ATTACH='D:\My Documents\Rubber\Suppliers\LCPI\PO 104001-4900034574-LCPI-2.pdf'
Presuming that you're running a 32 bits version of Windows...
Thanks Roelof,
I've just found 15 messages in my outbox! So, my code was working, the new messages were created there.
How can I open a new message window.
Help shows /MAILTO but, this just creates a new message in my outbox, too.
BTW: mailto links in webpages open new message windows well.
How can I open a new message window?
Thanks,
Andy
PS BatPro, 4.0.38;  W7 32 bit
Thank you,
Andy
The BAT! 6.7.36 x64
The final option for the /mail parameter is EDIT, the help file claims that that will open an editor window.
Thanks Roelof,
I can't believe I missed that!
Thank you again.
Thank you,
Andy
The BAT! 6.7.36 x64
