I am using v.5.0.36.2 pro (registered).
I have a problem with messages from a certain domain.
---Source example---
Content-Type: multipart/alternative; boundary="=_alternative 0050421BC2257AF5_="
MIME-Version: 1.0
--=_alternative 0050421BC2257AF5_=
Content-Type: text/plain; charset="KOI8-R"
Content-Transfer-Encoding: base64
In "HTML" tab the message appears garbled. On right-click>charset there is a tick next to KOI8-R but only after I select "Auto detect" or press Alt+5 it is displayed correctly (at this point the tick is still at KOI8-R).
In "Text" tab message appears correct.
While searching for a setting for this I noticed that in "HTML viewer" preferences all radio buttons are disabled (greyed out) and "Use system HTML viewer" and "Leave under IE control" are selected.
Any way to fix this?
MIME-Version: 1.0
