Autosize columns or save
Can the bat save configuration ? ie remember some things like dimensions given to columns by the user
Or an option to autosize by displaying all of the information for date received, created and size but share an equal dimension for from, to and subject if the information can be displayed in total.
You can save and alter folder view modes, one of the thing determined by view mode is the width of the columns.
When you don't use multiple view modes, but you want to store the changes you've made to the default view mode then you can tell TB to save them automatically at Options -> Preferences -> Message list -> View modes -> When view mode was changed -> save
That works ! :) Thanks you
