HTML error
The bat notifie of html errors (script errors) in some html email.
How to disable these errors ?
I don't think you can disable them. Nor do I think that would be advisable, after al;l you would like to know whether a message is displayed correctly/completely or not...
Yep but some users always send messages with these errors. At the end, when you can't manage to change the users :) and you are so fed up with this, you have 2 choices :
- classify the users as spamers which is not quite a solution, especially when they are "collaborators"
- drop the email software as it does not let you any other choice.
Ultimate thing of course would be, as the bat seems so much configurable, to disable these errors for some users only...
I found a way to "disable" script errors by choosing in preferences "Use the bat! html viewer". However the visual result is not good and html not respected. Example : i see a table in the "use system's html viewer" mode but just a text line with the "Use the bat! html viewer".
