Template font not saved in an empty template
I want to use a completely empty template when composing new messages. However, apparently I cannot do that.
I delete all predefined text withing the template and changed font to Tahoma, then saved. When created new message, the font was Courier... I tried it a couple of times with no result.
However, when I put ANY text into the template, the font change is saved correctly.
What should I do to have my desired font in an empty template as well?
Edited: mikolajek - 14 November 2013 15:38:33
Place some text in the template. Preferably a macro that doesn't generate visible output.
My suggestion would be the %- macro
