Crash when opening., TheBat often crashes when opening.
Hello,
Using vs 5.8.8 on Win7 32bits. 8 Go RAM.
Very often when opening Thebat, it simply does not open (!), I have to reboot computer, then I see that there are new empty accounts listed, and some accounts have simply disappeared from the account list (Though the files are on the disk). So I can use a backup to restore them in TheBat.
I have about 40 accounts, especially one of them with a large content (1600 emails with photos, more than 3 Go on the disk). Can it come from here?
When it refuses to start, run as ADMINISTRATOR and it should start - may take a couple of tries but then it is ok until the next time
When you have the bat open press "CONTROL ALT SHIFT L"   at the same time and all folders on in the mail folder will come back up. Then you can wipe anything you created and no longer want and just remove from the bat if it is a system file such as cache and imgfiles
Edited: Rick G - 29 December 2013 04:48:10
Will have a look, thanks!
But does it come from The large amount of files in a folder?
