Update directory!
Can you, dear The Bat programmers, check where users install The Bat and then upgrade it? I testing using "Program Files" directory (because I want it, no important why) and The Bat, no matter what entries are in registry, force to install new version in "Program Files (x86)". I don't care is this program 32 or 64 bit. If my installation dir is "Program Files" then upgrade should be in the same place where The Bat is already installed.
I totaly agree!!
