Textsize in Folders shrinking
Starting with  Version i have the Problem that the Textsize of the Folders in the folders pane shrunk to nearly unreadable, i can change Textsize for messages , but i can not find a setting for the folders ,
(win 8.1 pro)
a Friend of mine has the same problem on his Win 7 pro machine
If you have a middle mouse wheel, hold the pointer over the folder list, hold control and turn the wheel
Go to Options / Preferences / System and set it to exactly what works for you (note what is already there as to font and point size just in case ... ) :D
