How to move mail data to new computer?
I would like to move/migrate my existing mail folders from my old hard drive (in d:\mail data) to a new The Bat! installation on a new computer (in e:\users\minix\AppData\Roaming\The Bat!\Mail). The problem is when I copied everything in the mail folder over including all the separate sub-directories for individual accounts as well as the configuration files in the mail folder root eg. Account.CFN, Groups.CFG, AccOrder.CFG, Account.FLB, Config.CDB etc., The Bat! does not see them.
What am I doing wrong and how should I go about this?
Edited: David Paul - 05 August 2014 09:40:39
Start TB
Create a new account with the same name as one of your old accounts
TB will recognize the existing config
It's possible that you'll need to do this for every account, but also that TB recognizes all of them
Worked perfectly. Thanks! I had to add every account manually but they were all recognised once added. Tedious but otherwise problem-free.
Edited: David Paul - 06 August 2014 06:44:47
