I had the last version of the Bat installed (6.7.2) under windows 7 (64 bits) and worked fine. Yesterday I launched some antivirus and antimalwares. And after that impossible to launch The Bat. I always have the same windows error message at startup:
Exception EOleSysError in module thebat.exe at 00150BA6
Class not registered, ClassID:
{56FDF344-FD6D-11D0-958A-006097C9A090}.
It seems to be a Delphi error? I tried to reboot, install again or to remove and reinstall but nothing works!
I tried to reinstall some archived versions. I have the same bug with 6.0.12 but it works with 5.8.8 that I can use.
But if try to upgrade from 5.8.8, I still have the same problem!
Any idea? Thanks for your help!
