Feature request: Folder colors for new mails
before TB! I used Pegasus Mail for some years. It had a nice feature: Folders into which e-mails were moved by filter rules turned their colors to red, so I could immediately see into which folder the filtered e-mails went.
The folder color is reset before each e-mail reception, so the feature doesn't work 'cumulative'.
BTW: This is not the same as the bold style for folders with unread mails. (I have a lot of unread mails in different folders, these are mails I want to read or answer later.)
Stefan
On the lower left of the accounts pane you will see some tabs at the bottom. One is "All" another is "unread" where you can see all the folders with unread messages. I don't know that you can or can't change the folder color on receiving a filtered message. That would be done with the message filter. You would first have to set up some color groups then assign one as a folder color when it filters a message
You might be better off playing with the Bat for a bit and seeing how it goes.The bat covers a lot of the same features that you find in other programs in its own way
