The Bat! 64-bit not working with GPG4Win
Recently upgraded to new pc with 64-bit (Windows 7) and upgraded The Bat! fr om 6.5 32-bit to 6.8 64-bit, only to discover that it isn't working with GPG4Win. Whenever I go to sign an email, using one of my certificates, what we used to call a DOS box comes up referencing gpg2.exe and then just sits there doing nothing at all.
Going back to The Bat! 6.5 32-bit and it works just fine with GPG4Win..... BUT I lose the Windows Certificate Store option from The Bat! Simply doesn't exist under Tools - Address Book - View.
Any help with this problem would be greatly appreciated.
Update: Have just found wh ere to enable the Windows Certificate Store in v 6.5, so that problem is solved. However, would still like to be able to upgrade to 6.8 and use GPG4Win.
Edited: Lucht Siuil - 14 May 2015 03:49:26
The Bat! 6.8.2 64-bit should work with GnuPG.
