I would need to sort messages by column "tags". Just as it is possible to sort by sender or date. Should anyone advice, please? Thanks.
Can this not be done by adding the column header "TAGS" then causing to sort ascending or descending according to what is needed? I do this with Color groups
This is already how I try to do it, but it doesn't work
To Rick G: I tried that before I asked here. Unsuccessfully
The best I have come up with is setting up a Virtual Folder that searches/filters for the specific tag, then use the sorting functions that do work (sender, date, etc.). It isn't the greatest work around, but it does the trick for me. (I'm running Version 7 btw)
Edited: - 30 August 2016 18:27:02
I recently put in a support ticket and was told you can't sort on tags, but it'll be fixed in a future update. We'll see.
In the meantime I found that by assigning a color group to my tags I can sort on Color Group. I just confirmed it works in the latest version. Another way to filter them is create a message list filter for the selected tags you want. I have on that will display only a few of my main tags.
Edited: - 31 August 2016 03:49:38
