not downloading images, messages not downloading images.
Hi
Since almost 1,5 - 2 weeks The bat is not downloading any images more in the html view.
I didn't change the settings  they were always configured: the download of embedded images from external sites always.
and according to the rules of the bat.
Till today I used the 32 bits 6.8.8 version and upgraded it now to 7.0.0.56 but it made no difference.
I changed the settings to never, started the bat again, then changed it back to always and started the bat again up, but no difference.
Hope somebody can help me because this is very annoying.
Regards
Close the bat
Go into your mail directory and RENAME dwnloadrules.dat to something else
Restart the bat and set the Image download manager the way you  want (Mine is totally blank and set to ALLOW ALL)
Se if that helps - if so delete the renamed file and let us know if that did the trick
