Apart from other things I love The Bat! for its nice dispatcher (yeah, Pegasus has it too, and Foxmail as well, however they suck in different areas much more ;)
But, here the problem starts:
1. I ran out of space on my system partition where I had my Bat installed, so I just moved the whole program directory to another partition and changed the accounts' paths (I have 2 pop3's, however - just one required changing the path, another one has already changed itself to a correct one ;)
2. Now for the weird things: the "self adjusting" account works perfectly okay, another one (the one that required changing its path - dunno if it has anything in common, I've just noticed the coincidence) allows to send the mail, but refuses to dispatch new mail from the server. The account log says >Connection to host broken (last commands sent were: {"UIDL"} "TOP ##")< where ## stands for number of a message it crashed on.
I came across the post about similar behaviour of a dispatcher and it pointed to ACCOUNT.M_R and ACCOUNT.M_D files. Both are empty, 0b length. I also noted - maybe it's common procedure, dunno - that during the dispatch attempt the Bat generates bunch of 0 length .tmp files in the TEMP folder - number equal to the number of all mails on the account.
3. I deleted the account, set it up again from scratch and tried dispatching - same story.
4. I've just tried downloading all my mail again, without dispatching. It started ok, but then stopped again at the msg. no. 187 - apparently this is some big message w/ attachment - and returned the same error as previously.
I should also note, that for some time I've noticed very lengthy dispatching of mails that had big attachments - long before all this what I wrote here about happened.
Disabling AV plugin didn't help either (as some suggested)
Any ideas? :/
Any ideas? :/
