Hello all,
I'm wondering if someone can help me with this.
I've searched the forums but I cant find any information.
I have just joined a new email provider and I cannot send or receive email by using POP3 or send with SMTP.
When I receive I get this error showing in the log:
FETCH - receiving mail messagesFETCH - Connecting to POP3 server **** on port 995
FETCH - Initiating TLS handshake
FETCH - Server reports TLS error: Handshake failure.
FETCH - TLS handshake failure. Connect failed
When sending I get this error:
SEND - sending mail message(s) - 1 message(s) in queueSEND - Connecting to SMTP server **** on port 465
SEND - Initiating TLS handshake
SEND - Server reports TLS error: Handshake failure.
SEND - TLS handshake failure. Connect failed
I have checked all the POP3 and SMTP Authentication Settings and even according to the provider they are all set ok.
The provider has now said that The Bat! version 6.8.8 (which is what I am using) should be able to use one of the following ciphers:
TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 256 bits (ECDHE 256 bits)
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 256 bits (ECDHE 256 bits)
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA 256 bits (ECDHE 256 bits)
TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 128 bits (ECDHE 256 bits)
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 128 bits (ECDHE 256 bits)
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA 128 bits (ECDHE 256 bits)
TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 256 bits (DHE 2048 bits)
TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 256 bits (DHE 2048 bits)
TLS_DHE_RSA_WITH_AES_256_CBC_SHA 256 bits (DHE 2048 bits)
TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA 256 bits (DHE 2048 bits)
TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 128 bits (DHE 2048 bits)
TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 128 bits (DHE 2048 bits)
TLS_DHE_RSA_WITH_AES_128_CBC_SHA 128 bits (DHE 2048 bits)
TLS_DHE_RSA_WITH_SEED_CBC_SHA 128 bits (DHE 2048 bits)
TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA 128 bits (DHE 2048 bits)
TLS_RSA_WITH_AES_256_GCM_SHA384 256 bits
TLS_RSA_WITH_AES_256_CBC_SHA256 256 bits
TLS_RSA_WITH_AES_256_CBC_SHA 256 bits
TLS_RSA_WITH_CAMELLIA_256_CBC_SHA 256 bits
TLS_RSA_WITH_AES_128_GCM_SHA256 128 bits
TLS_RSA_WITH_AES_128_CBC_SHA256 128 bits
TLS_RSA_WITH_AES_128_CBC_SHA 128 bits
TLS_RSA_WITH_SEED_CBC_SHA 128 bits
TLS_RSA_WITH_CAMELLIA_128_CBC_SHA 128 bits
So my question is...
Does The Bat! version 6.8.8 support any of these ciphers and if not, then what ones does it support and where can I find this information?
Any help would be much appreciated.
Dan
Dan
