If I switch from The Bat! to using Voyager (taking into account I'll have to upgrade from Home to Pro) can I use a dedicated Dropbox directory/folder to hold my messagebase instead of having this on a USB Memory Stick?
One change I guess I will have to do is to setup (define) the appropriate local copy of the Dropbox directory as a local drive letter (e.g. T:\).
Are there any other reasons to not do this?
If it is possible, then how do I move my existing TB! Home messagebase into the Voyager setup? Guess via the Backup/Restore facility.
Thanks
Thanks
Richard
