Issue with %BCC in template, Don't know where it's coming from.
I am struggling with the template used in "New message" where I want to specify a %BCC value.
1) In my "Account Properties" I have got this template without a %BCC value  (see http://www.corobori.com/sos/picTheBatAccountSettings.png )
2) In my "Folder Properties" I have got this template with a %BCC value (see https://www.corobori.com/sos/picTheBatFolderProperties.png)
3) When clicking the "New message" the form seems to use the correct template but in the %BCC value I see more addresses than defined in the template (see https://www.corobori.com/sos/picTheBatNewMessage.png) Those values are the one I have used before but as they aren't in the "New message" template for the the "Folder Properties" and not in the "New Message" template for the "Account Properties" where else should I look ?
PS. Is it possible to add an image to a post ?
Maybe in the address history? See this thread for further information: https://www.ritlabs.com/en/auth-forums/forum4/topic13046/message44467/#message44467
I cleaned up completely the address history and it is still behaving strange
Besides the "a@a.com" I am using in the template the following text is added quot;xxxxxxx.praz@gmail.com,xxxxxx@hotmail.com">
Is a@a.com in your address book?
Have you tried moving the %BCC command to a different position in the template?
Got it Daniel ! The issue was that the %BCC field in the template was defined as an hyperlink. Per your suggestion I tried moving it to a different position in the template and noticed that by doing that it was screwing up things in the message so typed it again making sure to be pure text and it did the trick. See http://www.corobori.com/sos/picTheBatTemplate.png
Without your suggestion I wouldn't have found it.
Thank you.
Cool! :-)  Yes, now that you mention it, we should have recognized the hyperlink! Oh well, glad to hear that it's solved.
