Multiple SMTP-Server/Aliases to send from but under 1 account!, Something like google allows!
Picture explains it best, I think: https://i.imgur.com/RDVnQ7V.png
I'm looking for something like that. I have got 1 gmail-account, it's a collection, tag, and archiving account, say [email protected]. And I got 5 active Email adresses that I forward EVERYTHING from to [email protected] , there are no copies of these EMaily anywhere but on [email protected] .
Now depending to which Email I reply, I got the option to choose from 3 senders (each with their own smtp server, as seen in the picture). I want something like that in The Bat! To clarify. I DO NOT WANT 6 different accounts in The Bat! I want 1 Account [email protected], and from that Account I want to be able to send from [email protected], [email protected], [email protected], [email protected] [email protected]
Is that possible?
That is called 'email spoofing' and is generally considered spam. This happens because the sending smtp server and the from address don't match. TB! has the ability to provide this facility and does it well, but your approach is to disarm its strength. To achieve the ability to see all in one inbox and reply separately to each, I suggest you create an account for each email id and then set up virtual folders for inbox and sent folders. Works beautifully and transparently. I think you will like it. I have multiple email accounts and they all appear in one inbox. Good luck.
david
No, that's exactly the oposite of what I want: I do not want to send from [email protected], not ever.
I'll receive the email from [email protected] in my [email protected], account. And when I click reply, I will not be using the SMTP server from MyArchive but from ActiveMail01.
Example in the picture: My @googlemail.com will receive my @rub.de Mails. WhenI reply to @rub.de I won't be using google's SMTP but the @rub.de SMTP. Exactly, because of spoofing.
That's not what I explained. If you 1) stop forwarding to myarchive@, 2) set up accounts for each in TB!, 3) set up virtual folder for inbox, then whenever you receive mail into the virtual folder, your reply will automatically use the correct responding email id. This eliminates the need for myarchive@ account. I understand the intent, but letting TB! do the heavy lifting will give you exactly what you want: one inbox and automatically use the appropriate email id for responding.
david
Yea, I played with it around in the meanwhile....I likey! I made a common directory, put all the virtual directories there, done.
Only question I have: https://i.imgur.com/Pd0UFYD.png
Why are Misc-Combo, Spam and Draft with * and the other ain't? They were all before.
Edited: Martin Woltemate - 28 April 2019 17:31:12
David's suggestion sounds like a very good and simple solution.
Note that in The Bat, when you respond to a message, you can manually choose a different 'From' account quite easily - just click on the account name in the status bar below the editor. Maybe you can also choose a different 'From' account automatically through a macro in the template, I've never tried that.
Well, I've never seen * as part of folder names, so I'm not any help there; however, I'm not sure what you mean by a common folder for virtual folders. Good luck.
david
Yea, I went with david's suggestion. Better idea.
Now....what kinda plugins are out there? I know for Total Commander there's a dedicated fan-site for 3rd party plugins. Anything like that for The Bat?
