Command line bug, Space in FromName= parameter
Although the FromName= parameter is enclosed in quotes, any enclosed space causes the parsing of the command line to fail.
FromName="TestUser" will work but
FromName="Test User" will create the FromName as "Test" but any parameters (such as DelReceived) after that space are ignored.
As an aside, it would be very useful to have a parameter to set the "Check mail at startup" and "Periodical mail checking" options for the account.
Some more testing:
"C:\Program Files\The Bat!\thebat64.exe" "/ADD:User="TestAcct";InServer="mail.my.tld";OutServer="mail.my.tld";InUser="[email protected]";InPassword="TestPass";FromAddr="[email protected]";FromName="Test User";DelReceived"
All parameters in quotes - Incorrectly creates FromName “Test” but does not set DelReceived
"C:\Program Files\The Bat!\thebat64.exe" /ADD:User="TestAcct";InServer="mail.my.tld";OutServer="mail.my.tld";InUser="[email protected]";InPassword="TestPass";FromAddr="[email protected]";FromName="Test User";DelReceived
All parameters without surrounding quotes - Creates the FromName “Test User” but does not set DelReceived
"C:\Program Files\The Bat!\thebat64.exe" "/ADD:User="TestAcct";InServer="mail.my.tld";OutServer="mail.my.tld";InUser="[email protected]";InPassword="TestPass";FromAddr="[email protected]";FromName="TestUser";DelReceived"
All parameters in quote - Creates the FromName “TestUser” but does not set DelReceived
"C:\Program Files\The Bat!\thebat64.exe" /ADD:User="TestAcct";InServer="mail.my.tld";OutServer="mail.my.tld";InUser="[email protected]";InPassword="TestPass";FromAddr="[email protected]";FromName="TestUser";DelReceived
All parameters without surrounding quotes - Creates the FromName “TestUser” but does not set DelReceived
Thanks for your contribution Phil! Please note though that this is primarily a user-to-user forum. Any bugs found would be best reported directly to Ritlabs using the 'Support' option in the menu above.
