When trying to close the Bat I'm getting a pop-up box stating :"Compacting the folder//xxxxx//inbox" .The progress gets to halfway and freezes. When I click "Cancel" the wording in the box changes to: "Terminating the maintenance process" but nothing happens and the computer freezes.. (I.ve never noticed either of these boxes before)
I'm then unable to close down the computer, if I push the computer reset button, The Bat reappears with the same box "Terminating .........".
If I end the task through Task Manager (CTRL; ALT: DEL). The Bat closes but will NOT load unless I restart the computer.
I'd prefer NOT to uninstall and reinstall The Bat.
Can anyone help me with this?
If uninstall is the only way, could someone advise me how to do it?
I have CCleaner installed and I usually use that to uninstall less important programmes.
The Bat! version 64.6.8.8
Thank you!
Thank you!
