The response is: 5.0.0 Invalid domain name, Can Not Send Mail
Hi Kevin here again.....
I have just downloaded the latest version of the Bat Pro 3.50.16 and i am still having the same problem that i was with version 3.50.
I can recieve mail ok it logs onto the POP server and recieves my mail, although when i press send mail i get the following error message in the Log File as you can see i have cut and paste it here fo any one to look at and maybe steer me in the right direction on how to fix it. Using OutLook without a problem so seems be a problem with the Bat. I have all config data enterend 100%
Any info would be appreciated indeed.....
Thanks Kev
Below is from my log file
!5/26/2005, 21:14:38: SEND  - Server reports error. The response is: 5.0.0 Invalid domain name
5/26/2005, 21:14:38: SEND  - connection finished - 0 messages sent
5/26/2005, 21:14:38: SEND  - Some messages were not sent - check the log for details
5/26/2005, 21:15:49: FETCH - receiving mail messages
5/26/2005, 21:15:52: FETCH - connected to POP3 server
5/26/2005, 21:15:59: FETCH - authenticated (plain)
5/26/2005, 21:15:59: FETCH - 0 messages in the mailbox, 0 new
5/26/2005, 21:16:00: FETCH - connection finished - 0 messages received
5/26/2005, 21:16:19: SEND  - sending mail messages - 1 messages in queue
5/26/2005, 21:16:20: SEND  - connected to SMTP server
!5/26/2005, 21:16:20: SEND  - Server reports error. The response is: 5.0.0 Invalid domain name
5/26/2005, 21:16:20: SEND  - connection finished - 0 messages sent
5/26/2005, 21:16:20: SEND  - Some messages were not sent - check the log for details
Hi. I use The Bat 3.5 pro - trial. Had exactly the same problem. Tried to resolve it myself but no luck. I use 4 accounts and this kind of problem happens only with one. It's not a problem with configuration. I think that authentication  process should be improved. But not sure.  :(
Look whether the recipient's name is enclosed between quotes, something like "George W. Bush" <president@whitehouse.gov>
as always, i take addresses from address book.
